The only Different's is on the nozzles is the holes, one ore to hole nozzles.
and some old types use shimming instead of screw to adjust the pressure.
If I'm not to wrong the LD and and the LDS have the same type. 2 hole
So you don't get mutch more power out of it.
But there is a way to get more out of the fuel and so more efficient use.
You have to adjust the nozzles up to a higher pressure , and so you get more out of the fuel.
And the nozzles are German M.A.N type so they are easy to find new
Odd
