wehring
- 32
- 48
- Angleton, TX
Tonight I disassembled two different types of 5 ton locking hubs. AVM and Warn. In the pictures the AVM hub is on the left and the Warn is on the right. I took side-by-side shots of like parts between the two hubs so you can see the internal differences.
The Warn hubs were produced in two variants; the early hubs had nylon bushings and the later hubs had bronze bushings. This set has nylon bushings but I will have a set of AlBronze bushings made to replace them. The AVM hubs have brass bushings. This can be seen in the second picture.
Hope this helps.
Justin Wehring
979 997 3112
Hope this helps.
Justin Wehring
979 997 3112
