pa.rich
- 9
- 0
The control box innards are worn and so the valve would work for the pistons, but the pto control shaft on the other side of the control box would not get enough movement to engage/disengage the pto. Another used t.o. control box costs 300. And could be just as worn, if not worse. I didnt like the engineering of the set up anyway, so I fabricated a direct shift lever next to the tranny shift. Works nice and more direct. Now the lever by the left side selects power up , nuetral and power down and the pto lever on the rite of the tranny shift engages and disengages pto only. Attached are some pics and I took out the seats and seat belts to get better access and to prep the inside of the cab for repainting.Notice the floor mounted pivot plate for the pto shift, has no bolt thru it to enable flex of body and rubber engine and tranny mounts. It can slide through the pivot. This pivot is under the seat and will be out of the way. I made the shift lever and mouted a red pto knob on the end. I have to adjust the hydraulic control lever on the left as it is too high for me. Hope this helps anyone else with the same problem.
