- 2,863
- 1,407
- 113
- Czech Republic
My M51A2 multi fuel has been stationary quite long, awaiting repairs but moved a few times to make place for repairs on the workshop itself. Last time it was moved to a nearby field without problem. Now, 6 months later, the workshop is ready but I cannot get the truck started. Normally, even in freezing cold with half full batteries, I can get her started with a bit of ether start help. Now, no dice.
Even with two full and strong batteries (165 Ah-850 A and 180Ah 1000 A, no dice. Motor turns over ok and quickly, spraying ether lets the engine catch but it immediately dies again. My friends thought there maybe was a problem with air in the fuel lines due to long standing, but over the last 7 years, that never seemed to be a problem. It did sound like that though, or anyway a fuel problem.
I did make some stupid mistakes when trying to start:
First, I forgot to clean the first fuel filter. When I finally did, however, only a bit of mess from the bottom came out but good fuel came quite quickly after that.
Second, I forgot to do the "hydrostatic check". I did make sure before doing anything that the stop cable was released and the rod pushed back completely (it is causing my problems, hard to pull out completely, was noted for repairs). If anything, I now (home and relaxed) have the idea that there might be the problem?
Third, when starting, I did not notice that the fuel switch was shifted to R. I have two tanks, but the right tank has been disconnected as long as I have the truck. I shifted it back to the left tank, but still no dice.
Any ideas??
Any ideas??
