5 ton paint done
hank2424
Lincoln, ne
I used flat black, flat brown, and a satin for colors. they are all oil based paints, reduced 4 to1 with mineral spirits and sprayed with a cheap harbor freight spray gun. the seats are done with a product called deck over from home depot, it like a poly coat based paint, I thinned with warm water and used same paint gun."YOU NEED TO MIX IN WELL VENTILATED AREA" IT IS HIGH IN AMMONIA. the pattern I just started painting and came up with it. the good thing if you screw up repaint.
