5 ton Parts Quick Reference Spreadsheet
155mm
Chief and Indian
503
Guymon, OK
Thanks for the spreadsheet, there are a couple numbers that are in the wrong place,
line 91listed as air filter - napa fil 3472 is a fuel water seperator
fleet fs1251 is a fuel water seperator
Jakelc15
Hanover Pa
Power steering filter
International part fits m809 series pump.
Kit comes with filter, reservoir seals, spring and cup and new lock nuts for the reservoir.
djhenley
Clanton, Al
Does anyone have or know where to get the breather housing and filter element on top of the power steering unit pictured here, mine is broke off even with the housing
NMSMITTY
Elephant Butte/NM
I am trying to locate information on bearings and seals for the transfer case on a 1990 M923A2. A breakdown/ TM on repair tear down would be most beneficial. Not having much luck.
spook
Ft. Myers/FL
5 ton fuel filter:
The NAPA 3401 fuel filter for the 5 tons is WIX 33401
Not 44301
5 ton wiper blades:
Anco 51-18 is too long of a wiper for a 5 ton, isn't it?
My M923 has 14" blades. That is a 51-14
5 ton Oil filter o-ring:
Napa FIL 5271 crosses to a WIX 15271
The correct wiper blade for an A2 series does appear to be the 14" Anco 51-14. NAPA number is 60-1450.
36
St George, Utah
I'm sure someone else will be looking for one of these at some point
Serpentine Belt
NSN 3030-01-271-3754 (M923A2 / 6CTA 8.3L)
Dayco P/N 20-3945
Dayco P/N 5080680
Gates P/N K080680
Cummins P/N 3912004
L-68.00 W-1.125
Darrick23
Marshall Wi. 53559
Very helpful post thanks! I called for a rear wheel cylinder for my M817 using the Part # F6630 that was on this web site and the # was no good and could not be crossed.. Does anyone have a updated part number? Thanks!
68hunter
Canada
I am looking for a part # for the Air Dryer spin on cartridge/filter only (have one for the kit), Preferably NAPA. If anyone can help it would be greatly appreciated!
Jakelc15
Hanover Pa
M809 Starter
Ms53011-1
Prestolite M0017260MD
Delco Remy 1993924. Old# 1113847 and 1114853. Reman # 10461068
Gm# 8925579
Cummins 3603862RX and 3604321Rx
Delco 42MT
SAE type 3
11 tooth CW rotation
6/8 pitch
24v
