5-ton power steering pump
derby
S.E. MI.
The shaft and bearing housing look too long. The one simp5782 has in his photo is the correct pump for a Multi engine. You may be able to mount a pulley on it and fab a bracket for a belt drive?
I have found that alot of pumps have similar model numbers with a different suffix. And that can be the rotation, mounting flange, GPM or shaft configuration.
simp5782
Feo, Fuerte y Formal
9,268
Mason, TN
Or call TGR performance in Texas. They can make a power steering pump, small with alot of pressure and flow with remote tank for pretty cheap.
benand117
cuyahoga falls, oh
That's the thing I found a break down of vickers pump numbers and that pump has the same gpm working pressure relief pressure rotation and shaft as the ones everyone else is using. And it's only $150. Also I need to mount it on the injection pump because I'm running out of under hood room. I already have a belt drivin pump with an electric clutch mounted. But that runs the dump bed and the winch. I need the gear driven one for power steering.
Jeepjake
Bend, OR
pump gear and adapter housing
TNJ Murray also has gears and housing adapters that you can bolt the vickers pump to, I believe it is a standard bolt flange. As far as the pump specification I can not confirm. but you might look here , it is a great thread for a power steering conversion on the deuce with some info on the 5-ton pump.
cheers
Jeep
gringeltaube
Staff Member
2,282
Montevideo/Uruguay
Does this look like the right pump to you guys?
It's a vickers, the number is VTM-42-50-45-15-MF-L1-14-S4. .......
That IS the correct pump! (I have one that I purchased from the same seller.)
But is there supposed to be a gear on the end?
If you want to mount it to the Multifuel, YES, you'll need the gear, here: http://www.steelsoldiers.com/deuce-...f-power-steering-pump-m35a2-8.html#post959341; also the washer & nut and the adapter housing, of course.
G.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
I got one too, glad I kept the gear and adapter off my busted one. Someone needs to find a stash of these gears and mounts!
