5 ton pto rear faceing pto rpms ?????
6x6junkie
p.a.
hello have a 5 ton 800 series with a pto for the old dump does anybody no what rpm comes out of the pto facing the back thanks
gringeltaube
Staff Member
2,267
Montevideo/Uruguay
The (internal) ratio between PTO input gear and reverse shaft gear is 19:13 (1.46:1). And the rear facing output engages directly to the splined end of the reverse shaft (encircled).
The foremost gear on the #6353 countershaft has 43T. Now we need to find out the number of teeth for the input shaft and how many teeth for the countershaft gear, the one that actually drives the PTO input gear. Then I could tell you exactly the ratio; how many output shaft rpm for X-many engine rpm.
G.
