5-ton repair wiki
Robo McDuff
In memorial Ron - 73M819
1,477
Czech Republic
Thanks to some helpful members with a better memory, found back some very useful threads. What I would like to do now is following.
In the 5- ton section (or 5-ton and deuce,) make a sticky or wiki section with repair tricks.
Let’s copy those threads there. Then I will re-read them and delete ALL posts which do not add information. Posts that have useful information but also other remarks like: “good job etc, handy trick in step 5 is to do xxx” I will delete all unnecessary remarks and leave only the “handy trick in step 5 is to do xxx”. We can also merge threads so all brake repair stuff goes into one thread – or even one long posting, which starts with jacking up the truck and ends with letting it down again.
Those repair-threads would be locked but have links to the original thread or threads. If people like to add, they can do it in the original thread; we will then check it and add ONLY the useful info to the repair wiki.
That way, whenever somebody is looking for how to repair brakes, he/she only has to look at the 5-ton repair wiki to find all details needed. Only pictures and step-by-step explanations, no personal or unnecessary comments. No need to go through 10s of threads and reading 100s of posts to find out the step you need is still missing. That way, we can slowly build an on-line Haynes repair manual.
I would gladly offer myself for starting this for the 5-ton section; in the end it would probably even save me time as opposed to having to keep looking for the right threads anyway. I would need moderator rights for that thread or wiki to be able to delete and lock the thread.
What do you think?
Robo McDuff
1,477
Czech Republic
Thought I bump this up a bit again, probably a lot of people missed it. Besides, I hate threads without any reply postings. :???::???:
area52
San Bernardino CA
I would send a PM to members magnus580 ( I think that is his handle on here) and steelsoldiers so they see this. Other wise it will get lost in the shuffle of threads on here.
augiedoggy
13
Cincinnati Ohio
Sounds good to me !
Soooooo much good info on here, it can take a little while to find what'cha need......sometimes.
You're entering moderator territory :shock: I think...........
quarkz
Supreme Galactic Cleric
71
Kennewick, WA
I like it, but there definitely should be pictures of the processes, because I confuse easy.
Robo McDuff
1,477
Czech Republic
The pictures is the essential thing. ONLY clear descriptions and pictures, no other comments at all.
Area52m, good one, I will PM a heads-up to them.
