- 7,404
- 2,491
- 113
- Interlachen Fl.
Almost every truck that is now in public hands needs the rubber changed first thing
Take off the step too it's only four bolts you won't be sorry.
Most every pump out there needs to be taken to the right man and he will do wonders. Allways have them add 10lb to the rail side and keep the rpm at 2100. These P/T like use not sitting. They will go stale.
Replace you rubber and if the problem does not clear then you might be looking for the man. Use fuel lube allways and raise ctain 4 points.
Also if you have power problems you need a rebuild for shure. Hit peddel and slow to respond but seems to do the job. No well a good running pump and you feel the differance. Trust me I know.
