5 ton tractor converted to dumper
Bidslinger
mo.
I have a 5 ton that I have converted to a dump. Obviously running down the hwy with 10 ton load is a bit of a chore trying to keep it at speed limit. I have 2 questions:
What type of power gain will I get if I turn the adjustment nut on the pump?
And will I gain enough momentum with the 1600 x 20 tires that I am about to put on to keep the truck running at a respectable speed with a load?
I use the truck to deliver whatever to where ever
1,807
Cummins or Multifuel? The following is only for the multifuel.
There is power to be had but you have to follow the rules.
1) You must have a pyro.
2) See rule 1
1600s will compromise your power but undetermined how much.
Bidslinger
mo.
Re: RE: 5 ton tractor converted to dumper
2) See rule 1
Multi fuel with turbo. The 1600s are 52" tall and I don't feel I could compromise my power any more unless I could somehow split the gears.
Westech
CPL
6,104
207
cow farts, Wisconsin
RE: Re: RE: 5 ton tractor converted to dumper
you can really crank the fuel up and make a ton of power with the multi, but you can melt the engine down fast! the thing to do is just turn it up alittle and just let the engine do what it was made to do, work. You will never be a drivable power house with a multi but if you play fare with her she will get you anyplace you need to go, just a little slower then most.
