panzerwillie
- 295
- 83
- miami florida
I have a little play up and down on the yoke that conects the transmission and tranfercase , now the only reason i notiece is because the UJOINTS has play so will be replacing it maybe saturday and , i like to look at the play on the TRANFERCASE YOKE , its that preloaded , or bearing can i remove it out by ltaking the assembly out it has a cover with 5 or 6 bolts around , maybe the yoke its loose mostlikely not that if its a bearing problem , can i replace it with out taking the tranfer case down and apart its there a TM on that i have all the manuals on CD thanks
