5 Ton VIN for SF97?
CIH7777
WI
Just bought my first M931A2 and looking forward to going thru it and use it around the farm and for parades. I looked over it and could not find any of the numbers on the dash or frame that state the VIN so I can complete the SF97 application for a title. I noticed one label on the dash that states the S/N and then there is a much longer number below that but it does not say it is the VIN. Any suggestions where I should look and how many digits are usually in the VIN on these trucks?
It is a 1991 model with hard top and no winch if that helps.
Coffey1
493
Gray Court SC
On frame near steer gear box
The number below should be it mine starts out with the nolz or whatever may be the case
Castle Bravo
Hundredaire Socialite
226
Arizona
It should be what is listed on the "Identification No." line of the data plate.
For a M931A2, it will be something like this -
1007AAxxx
1007ABxxx
1030AAxxx
1044AAxxx
2007ABxxx
31/xxxxx
The National Stock Number (2320-01-230-0302) and contract # (DAAEXX-XX-X-XXXX) are not unique to your truck.
There is also a six digit identifier that is the truck registration number. Some will be letters and the first digit will be an "N" This is different from the VIN or serial number.
I have seen some trucks with the registration number stamped in front of the serial number on the data plate.
I don't believe A2s have any serial numbers stamped in the frame.
Hope this helps.
1 Patriot-of-many
69
Zimmerman MN
1007AAxxx
1007ABxxx
1030AAxxx
1044AAxxx
2007ABxxx
31/xxxxx
Hope this helps.
I agree, I have yet to find any of my A2's with a serial number stamped on the frame. Should be a black plate on the dash right side with 31/xxxxx
Gunzy
65
Roy, Utah
Frame stamping of the S/N is usually a result of an O/H at some point. My m923 does not have it but I have seen many others with it. Hit and miss but pretty sure is has to do with an O/H.
98G
Former SSG
4,192
My understanding is that the AM General trucks all have it on the frame, and the BMY trucks only have it if they went through O/H at some point, and hit and miss with that. I sold an M931A2 that had it stamped into the frame, and I have an M923A2 that does not have it anywhere except on the dataplate.
98G
Former SSG
4,192
Left front frame rail. Horizontal, not the vertical numbers which are stamped a little further forward.
I don't have an A2 on hand that has it or I'd post a pic of that. I recently sold an M931A2 that had it there - the buyer verified it at handoff.
CIH7777
WI
Thank you everyone. I did not notice a number on the frame by the power steering pump so I will use the S/N off the dash data plate.
