5 Ton Winch Shear Pins
DOCUSN1
western,ny
Hi all does anyone know where to get shear pins for the 5 ton 809 series trucks front winch ? I need to order some and some info I have found seems to be getting old. Hope all is well with everyone stay warm thank you. Mark:roll:
supermechanic
poconos, pa
3/8 inch aluminum bolts work fine, McMaster-Carr has them.
Do Not use anything other than aluminum, even the softest grade steel is much to hard, and will cause driveline breakage.
cranetruck
75
Meadows of Dan, Virginia
Hmmm...the m656/xm757 5-tonners use the same winch as the M54 or M809 trucks, but specify a copper alloy (5315-00-880-5861 vs 5315-00-209-7979).
supermechanic
poconos, pa
Always a spoiler out there.
It boils down to this,
The pin is designed to be the weakest part, don't substitute something that will make gears and u-joints the next weakest part in line.
Thinking people will make thoughtful choices,
If you have no source for the original part, you will find a reasonable substitute.
No, it won't be 100% original, but if this is for a working truck, which mine is, then 'field expediant solutions' become acceptable.
If you are doing a museum piece, then by all means purchase the two dollar gadjet with the ten cent function, as it will never need replacement.
If you have access to the specified items, so much better.
My caution stands, do not substitute a hard pin for a soft one, it is there for a very good reason.
M543A2
10
Warsaw, Indiana
I machine all of my winch shear pins out of 6061-T6 aluminum bar stock. They have worked well for both 2 1/2 ton and 5 ton winches for many years. I have never gotten the impression they either failed too easily or were too hard. If I fail one, I figure I should have used different rigging!
Regards Marti
DOCUSN1
western,ny
Thankyou for the valuable information gents I will have to substitue the actual pin with a soft aluminum one as I have not found any pins so far. Seeing my truck is a worker I need the wich to work. ThankYou again Mark
