I did a thread on the inexpensive diesel fuel pump I purchased.
I needed a little more reach on the hose and the limber pickup hose it came with was a pain so I made a pickup tube for my drums. A 2" pipe thread will screw right in the metal drum hole so I used a 2" NPT thread to slip fit coupling and reduced it with a 2" to 3/4" slip fit reducer. I used a round file to remove the lip in the 3/4" part and to take the taper out so a piece of 3/4" PVC pipe would slide through that part. The outside diameter on 3/4" PVC pipe is a little over 1" so the diesel hose will fit over it. I cut a short piece off the hose to fit the inlet fitting that came with the pump kit to the bottom and set the depth to be a couple of inches off the bottom of the drum. This will work great for topping up my tractor tanks as I use the fuel off. Having the pickup off the bottom will protect from picking up water if I get any condensation. I will periodically check for water by pumping directly off the bottom with a fuel pump I have setup with a metal tube on it. I vented the drums with a filtered air compressor muffler screwed into the 3/4" vent hole in them. Some will argue this will cause condensation to form but I have seen drums distort from expansion and contraction due to weather changes. I prefer to keep the drums vented and I will monitor for water in the fuel.
![PU-tube1.jpg PU-tube1.jpg](https://www.steelsoldiers.com/data/attachments/468/468621-176f639277c8ff86f962ea69bb137bf5.jpg)
![PU-tube2.jpg PU-tube2.jpg](https://www.steelsoldiers.com/data/attachments/468/468623-6aaba9b7e16aeea8961576cbf1a9a6c5.jpg)
I just used it to top off my John Deere and generator tank and it works great. The extra reach should help me get the hose outside the shed to fill my backhoe as well.
