58 Willys fording kit?
cajun66
Louisiana
I just bought a 58 Willys CJ5 (?) that has a hole in the starbord side of the hood. I figure it had a fording kit at one time but can't find ANY pictures. Can someone help?
Vetteguy66
Cartersville, GA.
Are you sure your Jeep is a CJ 5? It appears to have battery box on the passenger side of the cowl between the hood and windshield. It could very well be a M38A1 or have parts from one. You will need to submit more pictures to properly identify it.
1,807
Its a CJ-5. Most of the short hood jeeps had the fording kit notch with a plate installed. Lots of the early CJs also had that battery box. Lots of other tell tales that indicate this to be a CJ not an M38A1.
1,127
Kenny wins the prize!
CJ dash, no slave port indention in the right front fender, etc.
Many early CJ's used the M38A1 components. Remember, the M38A1 came first and it was such a hit that jeep chose to civilianize it into the CJ-5.
chowbutt
Holly, Michigan
I had a 57 CJ-5 in the early 60's and the place where the M38A1 battery box is located is spot welded closed and the glove box was located under it. Also the ford plate was spot welded in place.
