LuckeyD
- 399
- 63
- Vilseck, Germany
This is what is available from the military concerning this gen. Issues: Battery charging gen was changed in 2005, old ones still out there, both work.. Alternator hook up incorrect by soldiers, batteries changed to AGM batteries in 2010, injector pump and rack incorrectly installed causing various issues, not serviced, plugged radiators inside and out, incorrect S8 settings and load terminal connections causing Volt reg issues, fault panel issues, S1 and S6 sand intrusion and changed because of, K1 issues. Body panel issues. Once in order, this gen will serve you well and makes a great house power backup for some of your house set to 120/240VAC
For those who do not know about how the Army TM's are laid out:
1. LO is the Lubrication order. It tells you when, how and with what, about how to service the Equipment.
2. TM is for Technical Manuals
2a. TM's ending in -12 are the Operators Manual. A must read before trying to operate the Equipment
2b. TM's ending in -24 are the Unit, Direct Support and General Support Maintenance Manuals.
3c. TM's ending in -24P are the Repair Parts Listing for the Unit, Direct Support and General Support Maintenance Manuals.
Thanks to members , and anyone else who I might have forgotten for some of this information.
Basic TM's
LO 9-6115-641-12 dated 2009
TM 9-6115-641-10 dated 2009
TM 9-6115-641-24 dated 1993 wc#3
TM 9-6115-641-24P dated 2010
Engine TM's
TM 9-2815-252-24 1993 wc#3
TM 9-2815-252-24P 1996
Basic TM's
Engine TM's
