5th gear? In a deuce?
Cleptomaniac
Tecumseh ,OK
Well I my 5th gear is about gone. It is whining real loud! So I found one for 300$. It seems pretty strait forward to install it. But I have never done it. So if you guys have some advice that would be great!!
Danny
Cleptomaniac
Tecumseh ,OK
Lol no that is the whole tranny!! I'm not game for tearing in to a tranny!!
Have thought about keeping the one I take out and putting one of those taller ODs in some day :)
jwaller
19
Columbia, SC
those tallers gears are the shizznit. I'd never go back. it's more than just a gear swap though. it's a upgrade for the whole transmission.
jwaller
19
Columbia, SC
the only special tools you might need are a bearing puller and a press. thats it. the rest is normal hand tools and a very good set of snap ring pliers.
I did mine in about 4 hours and it was my first manual trans rebuild.
Heath_h49008
101
Kalamazoo/Mich
I always wondered about fuel efficiency/engine longevity with these things and bigger tires. Most of these trucks being driven unloaded, those would seem to keep the engine in that 1800-2000 rpm sweet spot.
The lack of leverage could keep your foot farther in negating the advantage... but I would like to see it tested.
rchalmers3
30
Irmo, South Carolina
A tranny swap?
Klepto, get crack'in! :wink:
It's big, but doable. Search for transmission or clutch replacement threads for some ideas on how to support that slug of a transmission. There are some good ideas on how to make a cab supported lift that is sufficiently articulated for stabbing that beast.
regards,
Rick
73m819
314
gainesville, ga.
A tranny swap?
regards,
Rick
A pipe though the front and back window and a come-a-long works great
OPCOM
27
Dallas, Texas
Good point and a deuce can get 10MPG with a few details done, but anyone who owns a deuce is probably interested in economy only as a statistic. I operated mine over a 4 year, 15K mile period on the highway at 2500RPM using 11.00x20 tires and it never had an issue. My goal is keeping off the redline and I happily went along at 55MPH. I turned up the machine to where it would just barely smoke and used a pyro pre-turbo to drive by. This said, the engine can produce its 300 ft-lb of torque at lower RPMs but this increases stress on some of the parts and jacks up the exhaust temperature at advanced throttle. I don't see anything wrong with 1800RPM, but 2200 would probably be a better fit for horsepower. It's more than torque that moves that beast. There are many here that know the LDT engine better than me, so this is just an opinion.
jwaller
19
Columbia, SC
Nice!! How much did that set cost? I haven't got a press but if I had a good excuse... :)
I don't remember exactly but they are on ebay as well as directly.
I got the 3rd set ever made and I'm loving life. you can cruise at 55 and have a nice chat with your passenger.
If you don't have a winch you should be able to have the trans out in 30-45min. it's really that easy.
mikew
edmond, ok
Easy enough job, doable in a day.
More-or-less:
Remove passengers seat
remove shifter
remove tunnel covers
remove trans to t-case drive shaft
disconnect clutch linkage
remove MOST bell housing cover nuts
poke a cherry picker through the passer door to support trans (overhead crane with soft top works too)
remove the rest of the bell housing nuts
slide trans back and lower to ground
reverse for installation.
Good time to do any clutch work, if required.
Check you throwout bearing. Mine works well but is very stiff, I'm sure it's gonna seize one day, and you have to pull the trans to change it!
If you're lacking space or lifting equipment, you can do it at my place.
Warthog
227
OKC, OK
Done a few removals and installs myself. Plans on a few hours.
I use a pipe thru the open windshield and a chain hoist to lower the transmission.
russ132
Kelleys Island OH
I used a four by four through the windshield and back window. I also used a chain hoist. I did use a chain to mount the hoist to the 4x4. I ran the chain through a five inch pipe and had the pipe on top of the 4X4. This allowed the chain to slide back and forth across the 4X4. Not a bad job at all but much easier with a helper when actually dismounting and mounting the transmission. I did a lot of cussing when trying it by myself. Have fun and play safe.
