- 1,863
- 1,400
- 113
- Laramie County, Wyoming
Hi,
I'm searching for a pair of 5th wheel spacers for the M52A2 5 ton tractor. As near as I can tell, these were only used on the M52. Here's the particulars:
part number 11608882
NSN 5365-00-422-2017
description: 2 steel plates made of one inch material, 5 1/2 inches wide, 31 1/2 inches long. These plates each have five 5/8 inch -18 holes and have six 11/16 holes. The 5/8 inch holes are for the thru and thru bolts and the 11/16 inch holes are for the large frame rivets.
I need a set of these for my M52A2. I have a set of M818 plates but they would have to be machined and drilled to fit correctly. I might be able to get the work done but it'll be a pain in the patooty.
