- 1,863
- 1,400
- 113
- Laramie County, Wyoming
Change 1, revision 2,3,4,5... okay, the tan 5th wheel is missing some parts. It appears to be repairable. I was looking at buying the parts when another avenue opened. The 5th wheel on the M931 will fit on a M52. However, some prep work must be applied. Since I had the M818 tractor adapter plates, I kept them for the install. The M931 5th wheel had its adapter plates still attached so I incorporated both sets to get this 5th wheel installed. I bolted the 818 plates to the 931 platesthen set the whole thing on the truck. Fit just like a champ!! One thing I will have to obtain is the “rails” that bolt to the truck frame and which are bolted to the 5th wheel. I’m not sure what’s available but something will turn up. Anywho, attached are pics of the installed M931 5th wheel sitting on a M52A2.
