5Ton Dump super singles?
kdk48095
Imlay City Mi.
I am considering putting super singles on a 5ton dump. After reading a few of the posts I am confused as to which wheel or rim to use. Some wheel sellers tell me that HEMTT will work with out modification and others tell me I have to use combat wheels. I was looking at using the 16.00 r20 tires. I also read that when using this size with the combat rims the tire will rub on the front. This truck is just for off road excavation. Can anyone clarify this and also should I just consider using the 14.00 r20 instead? Thanks
91W350
57
Salina, Kansas
I have some photos of an 817 someplace on 1600s I took my billfold and wedged it between the front and rear tandem tires, it was that close. Glen
dozer1
13
Sargeant, Minnesota
If you want to go with the 16.00's, the HEMTT wheels are the way to go, to avoid the front ones from rubbing when you steer. 14.00's will work fine on either HEMTT or combat wheels with no rubbing. 14.00's and combat wheels are the way my Marine Corps 817 was set up by the military. That combo looks great and keeps your gear ratio a bit lower.
dozer1
13
Sargeant, Minnesota
I THINK you need to put longer studs in the front. I have never done this, so maybe someone else with experience with that will come in and confirm that.
Floridianson
2,501
Interlachen Fl.
Front and rear useing the square head inner is what I do for the Hemtt's
av8or
fort denaud, florida
My m817 came on combat rims & 1400s I changed to 1600s and they will rub a little on turning on uneven ground but not bad should work ok. Had regular lug nuts front and rear.
Floridianson
2,501
Interlachen Fl.
Yea combat you are good with out useing the square. The front axle is wider than the rear. So talking with Pete today we could run Hemtt rims on the rear and combat on the front so the tires track in line better. If you run just Hemtt's all around the track is off.
Squirt-Truck
Master Chief
162
Marietta, Georgia
Has the bed been spaced for the 1400's?
If you are using it for severe off road service the 1400 and most definitely the 1600's will hit the bed during rear axle articulation. The 1100's get within 2 inches of the bed at standard install height. (This without a full load.)
BKubu
1,137
Gaithersburg, MD
Bkubu, do you mean the combat rims? Thanks
Yes, you and FLORIDIANSON are correct. There is nothing wrong with using the HEMTT rims. They tend to be more plentiful and are usually a bit cheaper...but you can find nice 1400s on the correct rims for in the range of $300-400. I have bought many from John Winslow in NC.
