6.2 Injector Pump Inlet Fitting
jj
Kutztown,PA
Greetings,all. Does anyone know the thread size of the fuel inlet fitting on the back of the injector pump? I need to replace some rubber lines soon and the line between the fuel filter and the IP looks to be a bit of a bear to get to. I'm leaning towards braided hose and A-N fittings. I don't like to do things twice and that stuff will probably outlive me at this point.
peter501
Oceanside, Ca
Did you ever find the fitting size? I have a brand new injector pump that I just I stalled and that small inlet pipe is the last thing I need to connect the fuel hose from the filter. If anyone knows the size or where to find one of these, please help. Thank you in advance.
C15TA
Castleton ON
JJ, like you I have considered the stainless line with the proper fittings which now come in black. I have to replace the lines anyway and install a spin on filter. The PO installed a Ford car inline fuel filter:cry: that I want to get out of there. My only reason for the stainless is I like the look.
Barry
skark_burmer
San Jose, Ca
Not sure where your truck came from, or maybe that was just a guess?
Anyways, its a personal pet peeve of mine when people post up incorrect information that they offer as fact with no checking.
(maybe your truck has been drilled out for a NPT fitting, if so i apologize)
But...
This isnt a NPT fitting that i just pulled from my 1028.
I dont have my thread gauge here but it is a flare fitting. I need to find a replacement and i'll post up with the exact thread when i check it in a day or so.
and yes i realize this thread is a few months old but it has been googled almost a thousand times, thats how i found it when i was looking for "6.2 pump inlet fitting" so i figured id post the correct information.
skark_burmer
San Jose, Ca
The actual thread of the pump inlet fitting measures 7/16 x 24tpi
It is the same fitting on a standard 1/4" hard brake line sold at most auto parts stores. Napa part# BL-460 for example. (Brake Line, 1/4" dia, 60" long).
I'll need to find that in stainless with a NPT or -AN on the other side for my SVO conversion, but at least now i know what to look for.
And so do you.
You're welcome. :)
I accept cash, checks or beer as thanks.
Sharecropper
1,161
Paris KY
The fitting is a 7/16" x 24 inverted flare. If you are going to be attaching a 04 or 06-AN hose, you will therefore need a 7/16"x24x-06AN fitting. That's what I did, in order to eliminate any possibility of leakage/air suction at this most inaccessible hose fitting. Back when I was setting up the fuel delivery on my P400, I bought the fitting from LeRoy. He may still have some, but if not you can probably get the fitting from Summit or other places. Here's a photo. Hope this helps.
Sharecropper
1,161
Paris KY
Yeah I just checked and Summit has them. The -06AN is Earl's Part #EAR-AT991962ERL. Attaching an AN hose to the fitting will completely eliminate any possibility of a rubber hose and a hose clamp from working loose and sucking air when running and leaking fuel when not running. Well worth the investment. Here's a photo of my fuel line before I installed the Bullet Supercharger Intake. The photo also shows the 700R4 bracket & cable in place. The red tape on the fuel line on the right of the photo is where my fuel pressure gauge attaches.
Dpaulson
Southern California
Wow that looks amazing 🤩 I’m gonna replace my rubber hose and make a setup like this, I have some leftover line so I just need to purchase a couple fittings. Thanks for sharing
