Lonesome715
- 25
- 48
- Columbus, GA
Thanks. I do plan to use the truck so any upgrade or fix I am interested in doing.
I'd like to remind everyone, this is not a CUCV. There is no big resistor on the firewall and the glow plugs may be different. I'd bet that the AC60 plugs will fit fine. It would be best to pull a plug and cross the number.Braunchitis said:Use Wellman 070's. These are the stock plugs that the military uses. If you go to Autozone or some such place, they will give you AC60's (I think?). These will not fit the stock CUCV glow plug connector, the tips are too wide.
When I needed them, I ordered them through INDUSA ($60 + shipping)
http://www.indusadist.com/web_site_new_2008_005.htm
Or, you could maybe use one of the other distributors listed on WAP's (Wellman's) page at:
http://www.wellmanautomotive.com/distributors.php
How about some under the hood pics?Lonesome715 said:Here are some photograhs of what I am working with.
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=26135
I still have no idea which forum it belongs in.
Being since it has a CUCV cab, wouldn't it still have the same military version of the 6.2? I am only guessing here. Can you give me some details on converting your to 12V and how you got the ne glow plugs to work?
I'm not really sure where to post it. It's not really a CUCV cab, just a Chevy cab of the same time frame. It's been a long time since I messed with one of these, but I thought they were already 12 volt systems. I remember that we kept glow plugs in stock for both the CUCV and the Eagle bobtails and they were different plugs.Lonesome715 said:Here are some photograhs of what I am working with.
The decal on the air cleaner will tell you if it's a "J" code engine. It isn't a 24 volt electrical system. The accessories are set up differently than the CUCV engines.Lonesome715 said:Does that look like a military 6.2 version?
