6.2l injectors
123mack
11
Jemison, AL
Thanks for the thread. I checked the links, one only had 6.5 injectors and the other was out of stock. The search continues.
HardCorps79
Kansas City, MO
If you don't mind forking over a fat chunk of change I believe realdiesel.com has a rebuild service. Have heard good things, but the prices are steep.
ralbelt
9
West Warwick, R.I.
I had mine rebuilt at a local diesel shop where the rebuild injectors and pumps,the truck ran great till a head gasket blew now both heads are out being tested and resurfaced. Rebuild of injectors was just under 4.
allrevup
Delaware
Rebuilding injectors is easy. Follow one of the many step by step instructions in this site and others, Cleanliness is very important .
The tricky part is how to check for proper atomization and flow balance between injectors... that takes know how and special equipment
Stoudty
Maple Plain, MN
Hi, I am new to the site and have a 84 cucv bought at an auction from a fire company. (We call it the Santa Blazer) Would bad injectors cause the engine to hesitate at a fixed speed of 55-65? It feels like the motor cuts out momentarily and then jumps back to full power? Thanks
ken
25
Houston Texas
I'm with ranch hopper. That's a simptom of a plugged fuel filter. And or a lift pump going bad. Check the oil for diesel in it. If the fuel pump is going bad it will leak fuel into the crankcase.
Stoudty
Maple Plain, MN
Thanks. I'm a real newbie at the automotive stuff. I already replaed the starter and did a 12 volt conversion. Whats the procedure for changing the fuel filter? Cna I find the how to in a haynes manual?
