6.2L Oil Pans
Tailwheel
58
Charlotte, NC
Anyone have a source for NEW OE or Aftermarket style oil pans for these 6.2L engines with the 2-piece rear main seal? When I removed mine about 9 months ago one of the lips was warped, I tried to straighten it but now its leaking like a sieve. Appears to be my only oil leak after replacing all lower seals and covers with new OE parts and its progressively getting worse and making an absolute mess.
Squibbly
1,030
South Carolina
Got a pic of the damaged lip?
Seems like someone here has probably fixed a few warped lips.
I'd flip it over on a flat surface and clamp a 1x2 (or something else that fits into the lip area) into the lip to straighten it if it's not too bad.
cucvrus
9,624
Jonestown Pennsylvania
I don't think the HMMWV pan will correctly fit on a CUCV. I have transplanted a few HMMWV engines into CUCV's and always removed the oil pan and replaced it with a CUCV oil pan. I may be wrong but if it does fit I knew it didn't belong there and I didn't want to take a chance of the axle tagging it. Good Luck.
