Wolf,ABN 173,
your advice works with a propper pre glow controler only. If you read the manual, you will find that the controler is designed to limit the glowing current after a specified period of time.
And the manual says: Never glow more than 2 minutes!
However, this will not work propperly with an overaged controler! So you have to glow 2 or three times due to the mullfunction of the controler, if the controler switches to the first reduction step imediately. If the controler does not shwich down, the plugs are blown!
Wolf
Just got a Engine Block Heater (NAPA 605-3180 $30.00)I have had my 1009 start at 5* without any issues (not plugged in)
Granted, I do prefer to plug in at any temp below about 20* just to be nicer to the engine....
Do you fry eggs on it too?I am new to Steel Soldiers but have some experience with cold weather diesels. It is true the M1008 I have started at 1 degree last Friday without a block heater. However I would hate to do that again. I just purchased this vehicle 2 weeks ago and it will be going to the shop tomorrow for 2 1000 watt block heaters. I will then be installing a 250 watt Proheat oil pan heater on it.
I put these on a timer and run them for 2-3 hrs before I leave.
I have used the block heater/oil pan heater combo with my 2 Mercedes diesels and they start like on a hot summer day. Plus the heat blows warm as soon as I start down the road.
Just my experience. Hope it helps.
Block heater, 750 watt, removed freeze plug, no big deal, when plugged in, it does not sound like a bag of hammers, Doghead is correct, hate to admit, they will start if everthing is working 100%, but seems to me it is better on the motor plugged in.
