6.5 detuned to a 6.2
CPAPPY
Xenia , Ohio
[FONT=Verdana,Arial,Helvetica]2 General Motors, mdl: 12460163-11, Diesel Engines, 6.2 liter, in containers. Unkn working condition.
[/FONT]
armytruck63
10
Morro Bay, CA
I was told once while looking at Humvees at an auction, that there were two versions of the 6.5's. One with more power, and one with cleaner emmisions. This is just what I heard, nothing to back it up.
Chief_919
104
Western NC
All the detuned part means is that the fuel rate on the injection pump was turned down so that the 6.5 had the same output as a 6.2 when put in a truck that had a 6.2 originally.
CPAPPY
Xenia , Ohio
THESE MOTORS ARE A 2001 . Do you know if these where good blocks . So all i would need to do is turn up the pump to get more output.
CPAPPY
Xenia , Ohio
I googled the mdl #
[FONT=CourierNew,Bold][FONT=CourierNew,Bold]
12460163-11 .ENGINE,DIESEL 2001,6.5 LITER 1
DETUNED F0R USE AS 6.2 LITER
REPLACEMENT.........................
UOC:AVY,A11,A13,A14,A15,A20,A24,A25,
A26,A27,B16,B17,B18,HVY,H11,H13,H14,​
H15,H16,H1
[/FONT][/FONT]
Stonepicker1
108
Coconut Creek, Florida
When you pick-up the engines, take a look at the front left side of the engine at the bottom of the head. I hope it 's not marked "6.2L"
You can't always go by what GL list as part # or NSN's. Did you click on the NSN ? It's listed as a 6.2L.
The engine "can" may have a different numbers then what the engine really is.
Think about it....New engine (6.5) is removed and installed in HMMVW. Old engine(6.2) is placed in the engine can that the new engine came in. Numbers on the can were not changed to reflect a 6.2L. It is then turned into DRMO for sale.
AMX
Walland tn.
Seriously, the term "detuned" usually refers to minor tuning modifications intended to reduce the maximum power output. Usually a tradeoff , less power for more longevity.
CPAPPY
Xenia , Ohio
Yes, that true . I have some doubt now that i have looked at some # . Well I will find out Wed. morning when I pickup the motors.
11Echo
96
CT W. R.
Seriously, getting a good, running 6.2/6.5 from GL is no better than a 50/50 chance at best. Don't count your chickens before they are hatched.
The motor shown here looked clean enough to eat off of and the can was spotless inside. The motor also had a window in #7 cylinder into the water jacket.
Chief_919
104
Western NC
Why would a 2001 6.5 be detuned to 6.2 output? Were 6.2s hard to come by at one point?
6.2 production stopped in the early 90's. There was still a need for engines meeting the 6.2 specs for HMMWV's, and it was far cheaper and easier to just turn the fuel down on 6.5's that were in production than keep two lines open.
The military was rebuilding 6.2's as well up until a few years ago, but now when a 6.2 is replaced it will always get a 6.5 in its place, and the 6.2's will not be rebuilt any longer.
Chief_919
104
Western NC
OK, looking at your auction- the first picture clearly shows an 80's GM sticker on the valve cover. That makes me 99% certain that one is a 6.2.
The second one has black paint on the intake manifold. That tells me it is a government rebuild. 99% sure based on that it will also be a 6.2.
The good news is now that 6.2's are no longer rebuilt, they will be removed and sold even for something easily repairable like a head gasket.
hre513
Indiana
:shock: That looks like a GEP 6.5.
