6.5 engine harness on a 6.2?
erasedhammer
56
Maryland
So I've been going over the a2 body harness that I will be using with my 4l80 and it looks like I will need a 6.5 engine harness because of the connections to the engine rpm sensor and the TPS.
Would a 6.5 NA engine harness work with a 6.2 engine?
86humv
487
Texas
Yes....I have some.
You will have to change the injection pump, or at least the upper section of it.
Pump rebuilder can do it.
erasedhammer
56
Maryland
Yes....I have some.
But the harness works with the rest of the components on the 6.2? And where would I get a different upper section of the IP?
86humv
487
Texas
Should be fine.
You need to find the whole Inj. pump.....A rebuilt one, or a takeout and have a shop go thru it.
I might have a takeout.
erasedhammer
56
Maryland
Should be fine.
And what kind of IP is this, a 6.5 NA IP? Or just any old diesel IP.
Also why do I need a new IP with the 6.5 engine harness?
