- 12,195
- 329
- 0
- gainesville, ga.
yes , then report back with the AAR.If I hit my d*** with a hammer I know it will hurt, Should I try it?
You wouldnt hurt the motor, it will run all day long at the governor. The motors are not as bad as most think, they just never recovered from the rep of the 5.7 converted gasser.
What Joez said...it'll run all day at the governed rpm without complaint. It won't be quiet and it won't get great mileage but you won't hurt it either.
The unfortunate thing with the 6.2 is that it is still mistakenly thought to be the same motor that GM started with, the 5.7 Olds block diesel. They truly share almost nothing in common. The 6.2 was designed and built from the ground up by Detroit diesel for GM.
Anyway, is this the right gearvendor? I don't want to call unless I am serious about buying. They don't list the K30 truck so I picked the one with the closest specs.Yes, you could run it at the governor for extended periods of time, but would be getting pretty bad mileage and that sucker would be loud.
Read the original quote....you presume that the OP has the ability to assemble a differential assembly, x2, and set the gear mesh properly.
'Tanner'
That would be it. After shipping and having your driveshaft shortned, figure $3500 in it if you install it yourself.Guys, the truck is not going to blow up if I keep it at or below 65 mph and if it does I am fixing it.
It is said you can only tow 3000 lbs with a M1008. We both know that is with the pintle, but I am probably ruining my engine. I had a 8 ton hitch installed. I do need a trans cooler if I plan to tow much.
[FONT=Arial, Helvetica, sans-serif]Part #3D0208A
1. DRIVETRAIN MANUFACTURER: GM
2. YEAR: 80-87
3. VEHICLE TYPE: Truck
4. TYPE: STOCK
5. WHEEL DRIVE: 4-Wheel Drive
6. MODEL: 3500
7. FUEL TYPE:
8. TRANSMISSION TYPE: Automatic
9. TRANSMISSION MODEL: 3-SpeedNP-208 T-350/400
Price: $2,995.00
[/FONT]Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
I can't believe how many folks overlook this very worthy mod. Chief, tell these folks about how your does including mileage.That would be it. After shipping and having your driveshaft shortned, figure $3500 in it if you install it yourself.
You could have a good transmission builder build a 700r4 to handle the power of the 6.2 for half that, installed.
Unloaded, running 65 on the highway I can get it over 20mpg down in the flatlands. Averages around 19 here the mountains due to all the hils.I can't believe how many folks overlook this very worthy mod. Chief, tell these folks about how your does including mileage.
My recent experience was the convoy to the GA Rally. We ran 50 -51 on the way up and I must have gotten 15 MPG. On the way home I rann 55 to 57 and it dropped to barely 10 MPG. The 700R4 will get the 6.2 back into fuel miser RPM range and help you cruise at 65 to boot. Added bonus, deeper first gear for takeoffs.
...owning an adjustable wrench doesn't make one a mechanic.Read the original quote.
-Ian
