6.5 Motor replacement cost
Salty dog
Spring, Texas
Looking at a 1123 with the 6.5, motor has the intake manifold off as well as the fuel injector lines disconnected. Did not do a complete inventory of everything under the hood. standing Water on top of the block. Wanted to get a ballpark of what it would cost labor wise to swap the engine out. Personally, it's been about 20 years since I pulled a motor.
TOBASH
3,966
Brooklyn, NY
Companies used to sell pullouts. Engines with tranny and xfer cases. 2-4 thousand.
RWH charges 8 K.
Others have gone to buy used marine or civilian 6.5 Detroit Diesels at junk yards.
You should start on our classified adds and with site sponsors.
NDT
7,515
Camp Wood/LC, TX
Takes about 4 hours to pull the engine out and minimum of 8 to put a dressed engine back in. Your swimming pool engine might be rebuildable, knock the pistons out and see how bad the cyl wall pitting is. Might clean up at 020.
springer1981
1,184
Maine
I do not know if that 1123 has a 3 speed or not but this could be an option, even comes with a TCM and looks absolutely new and it is local to you.
I would definitely try some negotiation.
https://houston.craigslist.org/pts/7556553937.html
It is a little disconcerting he is not running a filter into the IP for test running.
I saw that about a week ago and it was originally listed for $7000. He's gone up $1500 in a week. I bet a good negotiator would get it for $6K.
Mogman
10,586
Papalote, TX
Mogman. Nice find BUT that’s a n/a $2000 engine. $8500 is way too much IMHO.
I did say to negotiate, cash is king right now!! I did pick up a turbo GEP with about 100mi on it for less than 2K but that was like being hit by lightning, would never happen again. I think somewhere between 4-5K considering it has a trans, transfer case and TCM all like new would be a good deal.
