Well after the issues I encountered with my 6.2 block and failed rebuild I decided to purchase a new 6.5 Optimizer. I'd like to have everything I need on hand when it arrives so ideally it is a fairly quick swap and I don't have to wait for parts.
I've heard that the few remaining bolts on the 6.2 that were standard thread are now metric on the Optimizer. However, I can't seem to find a list of which exact ones these are and the correct metric replacement for them. I believe two of them are:
- Bellhousing bolts
- Motor mount bracket to engine bolts
I'm looking for assistance on whether there are any other bolts of interest that also are not compatible from the 6.2 and what is the correct metric replacement for the ones I've mentioned as well as any others. Also I would like to know if there are any other differences between the Optimizer and 6.2 that are of note which will require different adapters/fittings/etc. The only other item I'm aware of is the oil cooler line block fittings are a larger NPT thread (I believe 1/2" vs 3/8") but I already have replacements on the way from Leroy Diesel there.
- Bellhousing bolts
