6.5l injectors on 6.2 w/ 6.5 IP
erasedhammer
56
Maryland
So I have a 6.5 injection pump on my 6.2, and I plan on replacing my old injectors soon but I don't know which to get, 6.5 or 6.2 injectors...
I am mostly worried about EGTs being too high. Is there a danger to adding those 6.5 injectors to my setup?
Also what's a good reliable source for new injectors? ebay seems to only have used ones, hummerpartsguy maybe?
TOBASH
3,070
Brooklyn, NY
As far as I know, EGT's run hot under LEAN conditions. I assume the 6.5's push higher volumes potentialluy creating RICH conditions.
Feel free to correct me everyone.
Ciao,
T
erasedhammer
56
Maryland
Ciao,
T
Well since I don't have that extra 0.3l that the 6.5 would normally have, I assume a 6.2 thats pushing a 6.5 amount of fuel through it would run richer because of the lower volume of the engine?
Monkeyboyarmy
192
Kingsville,Oh.
No such thing as a lean burn in a diesel. There are no throttle plates on a diesel to limit air flow so they get all the air that they can all of the time. Adding more fuel adds more heat.....to a point.
erasedhammer
56
Maryland
So I should stay away from the 6.5 injectors? the 6.5 IP I got was rated for 165 hp, I'm guessing the 6.5 injectors would really turn up the heat though.
