6.5L NA Injection pump
tanhmmwv
ma
I have a 6.5 IP that is leaking, was rebuilt motor and appears that the underside of the IP was cracked then welded.
does anyone know if the 6.2 IP or Artic kit 6.2 IP will work on a NA 6.5L motor?
both are mechanical, but with the 6.5 having a bigger piston, not sure if the Arctic IP will work.
They look very similar on the outside, a little difference in housing shape, thats all.
Thanks, Paul
Chief_919
104
Western NC
The 6.2 pump will bolt on and work fine. You will get just a tad less fuel, but you can turn the fuel rate up once you get it mounted if it actually makes a difference you can feel- but I have done it many times and never needed to.
You can actually use the 6.2 pump on a 6.2 or 6.5 turbo, just turn the fuel rate up a bit.
