6.5TD Boost
twisted60
251
Jupiter, Florida
Anyone install a boost gauge to see what their boost is ? If so what did you get ?psi.
I installed boost and fuel pressure gauges and looking to compare readings.
At 2500 rpm and 60 mph i see +/- 5 psi boost and +/- 10 psi fuel pressure.
Thanks
Mogman
10,589
Papalote, TX
Sounds pretty normal, you can convert to a manually adjustable waste gate and get about 10psi boost, you do not want over 12-15psi fuel pressure as it affects the IP timing.
You will not notice much if any gain.
