6 inch stacks on deuce
saddamsnightmare
80
Abilene, Texas
October 5th, 2012.
Normally, I wouldn't comment on a permutation like the one above but....
"Everyone to his own choice!" said the farmer as he kissed the pig. I have no problem with the stock exhaust on the deuce, and I regret to say that this system is comparable to the ones I see on diesel pickups all the time.... equally useless and ridiculous, but as they say, it's your truck. I always figure someone's trying to compensate in size for something else....
The only problem I ever had with the stock deuce exhaust is that it is in front of the passenger side cab door, not behind it like the 5 tons...:nothingfunny:
Hopefully the situation is reversible, because beyond hot rodders, this bird probably wouldn't fly.
NMC_EXP
12
Raton, New Mexico
Over the last few years the local semi truck owner/operators seem to be competeting on who can install the largest pipes.
I'm waiting for one of them to show up with 14" corrugated culvert sections. Then the next guy will raise the ante with brick and mortar chimneys on his truck.
The big pipe drivers are usually the ones who have the seat adjusted all the way down to the floor so the top of their head is level with the steering wheel.
Takes all kinds
Regards
Jim
steelandcanvas
86
Southwestern Idaho
Am I see a ridgid mounting connection between the stack and the cab tub? If so, wouldn't you want to let the mounts flex a little, to absorb any torque? Just trying to learn, not ruffling any feathers.
jrobinson5093
jakin georgia
I solid mounted the stacks and the t pipe to the cab, but it all flexes right at the bottom back of the cab. I also have flex pipe under the cab to allow for engine flex. I have found that if I dont solid mount the stacks they will kinda flop in the wind so to say.
