robertsears1
- 119
- 43
- Near Apex/NC
Through Ft Bragg GL, I bought this fuel pumping unit. It has a 60 kw civilian generator powered by a 4 cyl turbo diesel Perkins engine, 20 hp motor driving a fuel pump and associated electrical switches and panel. The control panel is a Deep Sea Electronics and it says the engine only has 112 hours since 2007. I am familiar with MEP generators (I own 4, 002,003,804a,804b) but have never run a large civilian generator. I found some information online for the control panel and engine. I connected a second battery to the electric fuel pump and solenoids on the injector pump (IP) since this was the only way I could devise to prime the engine. The fuel tank was not present so a jerry can is a temporary replacement. Fuel circulates and returns to the tank. The problem is that fuel is not going from the black manifold with the yellow sticker on the IP out to the injectors at the cylinders no matter how much I run the fuel pump. The are two electric solenoids on the IP, the upper seems to stop fuel flow for shutdown while the lower one seems to be a safety if the coolant temperature gets too high, both work when powered by the second battery while running the fuel pump. Any suggestions are welcome. I bought this unit to power a large compressor and blast cabinet.
