600 gallon fuel pod dimensions?
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
Does anyone have one of the 600 gallon fuel pods that they could take some measurements from? Specifically, I am looking for the measurement between the skids on each end, the width of the skids (or a measerment from outside to outside of the skids), the overall height of the skids when sitting on the ground, and the distance the skids protrude from the tank base.
Thanks!
FMJ
37
Las Cruces, NM
I've got some I can measure when I get home today. Also, a while back I submitted the TM for tank and pump unit, not sure if the dimensions for the tank are in it though.
emmado22
162
Mid Hudson Valley NY
Make sure you get the info for the right pod. There are like 6-10 different manufacturers of the pods, and they are all slighty different.
FMJ
37
Las Cruces, NM
Skids are tappered from the bottom (wide) to the top (narrow) at the top 24" between "ish"
width between skids outside edges 45" ish
Overall length of skids, 61.5" ish
skids approx 7" ish tall
tank overall height, 57" ish
