I picked up two at Napa last year. Decent price if I recall.Can anyone point me in the direction of reasonably priced 6TL AGM's?
"AGM" sounds more advanced than "VRLA" or "Lead Acid", Which is all they are. They're Still an h2 producer when over driven. I've had inspectors demand that AGM must be used (off grid batteries and data centers) because "no h2 is produced". Labels make for bad chemistryIMO AGM batts are a little overrated. They do deliver a greater CA per pound, so in a vehicle where weight is important, like an airplane, boat or quad/motorcycle, they make sense. They are a little more resilient to being pounded on, so again a quad or a UTV they make more sense than a vehicle that spends most of its time on paved roads…. Beyond that they are still a lead acid battery with the same basic requirements and failings…
As long as the alt can support themThe military likes them because they don't leak and are MUCH less affected by low temperature. They can also suffer minor damage and continue to function (think a crack in the case, etc). A wet cell will leak out the acid if cracked and cease to function (no electrolyte = DEAD) while an Absorbed Glass Mat battery will keep working with a minor crack to the case as it will not leak out it's electrolyte. So they are more suited to the military where cost is secondary to mission suitability.
I personally run 4 x 6TAGM's because of these reasons, and specifically I run four since a single battery failure can be reconfigured to a two battery system and still function to get back home. With a two battery system you have zero options if you have one that decides to fail, explode, crack, melt off a terminal, etc, etc. You are SOL.
If I were trying to save coins I would reconfigure to 4 x Group 31's - either SLA or AGM depending on how much you want spend. I can get the Exide Sprinter van SLA Group 31's with stud terminals for CHEAP (like $145 each delivered to my shop) since sprinters are everywhere right now. And they have 950 CCA. Have a pair in my CUCV.
Right. Everyone in this forum must consider that, unfortunately, since S&S didn't. It boggles my mind that my CUCV from 1984 has twice (200A) as much alternator(s), half as much battery (two 6TL's or two GRP 31's), and predates the FMTV's by a decade. The DOD should have made S&S fix them at their expense. Someone got paid on that dealAs long as the alt can support them![]()
