6x6 help
sigo
Lieutenant Colonel
400
Leavenworth, KS
Is the switch plate on the dash and just the switch is missing, or is there no evidence a switch was ever present? Might be a sprag transfer. Search sprag in the early deuce and deuce forums.
Katahdin
24
Scarborough, ME
Sorry bud, old deuces don't have 6x6 switches, front wheel drive is activated by a sprag clutch within the transfer case when slippage in the rear occurs. They can be temperamental and/or require linkage adjustment, or just be plain worn out. Download the technical manuals and search the website for "sprag." Good luck!
212sparky
Monroe/ Ohio
By the way. Welcome to the site. If you have not had a chance, down load the technical manuals (TM) and brush up an a little light reading. they are the best repair manuals you can get.
Theduece
White oak tx
I don't even no the year on the truck it has a info plate on the dash but the year was never stamped and the engine in it was made in 88. Where can I get a tm for this truck Id tried google but can't find much
