6x6?
nile62
Stout, Ohio
I have a 67 M35A2 deuse and the front wheels sometime pull and sometime dont pull, what is causing them to kick out?? PLEASE HELP!
it has no switch so i assume its a sprag. some times i take it up a hill and it pulls just fine then the next hill the back wheels just spin...is that normal? could something be broken?
steelandcanvas
87
Southwestern Idaho
Sounds like you have a sprag tranfer case instead of air operated. A sprag unit will engage the front axle after a certain amount of slippage in the rear axles. The air unit is controlled by a switch, bottom center of the dash. DEUCE!
nile62
Stout, Ohio
