700R4 transmission in a HMMWV
dhaumann69166
78
Hyannis, Nebraska
Thanks guys for all your help. I'm definitely gonna move forward with the 700R4. I'll do a write up for anyone looking to do the same.
Looking forward to following your build. I am getting ready to do a 700r4 with a 241C. Everyone keeps saying it won’t hold up but I have personally seen them handle 750hp rock crawlers and 1000hp drag cars. Most of them were only mildly built.
Bocephus
Iowa
Agree with you there. I've seen several people say the 700r4 won't handle it.............which leaves me scratching my head because its a 165hp motor........... Like you, I've seen them in several built rigs, and they handle it just fine.
Sharecropper
1,186
Paris KY
C'mon man.
If built correctly, the 700R4 will handle as much as a TH400. I purchased a Level 2 K-case 700R4 from Bowtie Overdrives rated at 450 HP and 400 FPT. $1650.00. Added the special output shaft to mate with my NP208. The length of the 700R4 is the same as the TH400 so no crossmember or drive shaft modification is necessary.
https://www.bowtieoverdrives.com/catalog/catalog_inc/viewitem.php?ITEMID=503
Dock Rocker
72
Jackson ms
Horsepower isn’t what kills transmissions typically, it’s heat. Get a well built 700r4 with a beast sun shell and upgraded clutches and the biggest cooler you can find. The cooler adds capacity (more fluid) and cools faster. If you do those things you will be fine.
davykeith
Ellisville, MS
Ran into a snag on my conversion. The flexplate on mine is a six bolt pattern and it's not lining up with the three bolt hole on the converter. Any suggestions? Thanks.
86m1028
17
Murphy TEXAS
I’d say TORQUE & heat kill them.
Agreed, bigger the cooler the better.
I think ANY trans will stand up behind a 6.2 !
I guess if you putt around in an empty truck (mall crawler) it will do fine.
There is a reason Gm never put them in anything bigger than a underpowered HALF TON !
davykeith
Ellisville, MS
Replace your flex plate with the correct one for a 700r4.
I went to Napa and they gave me BK 600541. Based on the research I've done, I believe I need BK 600542. I hope that's right because my mechanic is going to kill me if it isn't. It's holding up his lift. I know this sounds silly but I printed both pic's out and lined them up in the light and the holes are in different places. Fingers crossed.download.pngdownload (1).png
davykeith
Ellisville, MS
Update: The part number FRA143 flexwheel had the correct hole pattern for my 3 hole torque converter. And just for the record, it's a 6.2 diesel I'm not converting from gas to diesel or vice versa. Still same motor. Drive shaft had to be shorted a bit, 1.75" or so. Small bracket adapter fabricated for the drive shaft and so far that's been it. It's going in today. I need to figure out how to do a lock up on it next.
Dock Rocker
72
Jackson ms
The rear shaft had to be shortened? Thought the 700r4 was close to a bolt in. You using a 218 or 242 transfer case?
Matt
The adapter used to mate the different spline count 218 to the 700r Necessitates the different driveshaft length.
davykeith
Ellisville, MS
Both my cars run LT1 against 460LE. Is not that the same and/or better than 700R?
There is PDF attached. If you see just a black boxes just click on it and it will work.
It depends on what your meaning of "better" is. Yes as far as a more robust trans but no as far as cost and if you want to stay away from electronics and have a dumb trans. I prefer dumb and I'm only looking for grocery getter not offroading really.
