700R4 Wiring info
tut69
Ogdensburg, NY 13669
I have just installed a 700r4 to replace the original 400 broke by GL. It works fine but I need a simple wiring diagram to hook up the lock up torque. Cant this be done without an expensive internal mod? Thx
Westech
CPL
6,104
207
cow farts, Wisconsin
you can install i kit to work the TCC. Painless wiring and B&M make a kit for around $125.00. Look at Summit racing. I have used the B&M one before and they work great.
jwaller
19
Columbia, SC
supply 12 V to either the front or rear terminal on the outermost side of the transmission and whichever terminal you don't use ground that one. the 2 terminals closest to the transmission are not used in this application. unless you are wiring up daytime running lights.
now do remember that depending on application and yr model of the doner transmission you may have wiring in the pan that goes to pressure switches and temps switches that only allow lockup in certain gears.
you will never be able to lock up the conv in 1st or R.
FMJ
37
Las Cruces, NM
Also, make sure your TV cable is working properly (controls pump pressure based on throttle position) if it's not right, the tranny wont last long....
ETHOS
Michigan
bingo, spend no money
86k10
Bertrand, Nebraska
yes all you need is power to terminal A which is the outside rear. That's all you need provided everything else inside is there. By the way what is the year of trans you put in?
kennyw
Stones Throw from Reiter, WA
I have a stock 700r4 wiring setup I pulled out of my K20 when I converted to a TH400... Including the IP pump switch that replaces the vacuum switch on the TH400. Pay shipping and you can have it.
EDIT: please don't PM me about these parts anymore. They are long gone now.
bgekky3
Huron, Ohio
You can put two switches and lock in overdrive power to one terminal and run second ground to lock in second and third ( I can't remember which ones off the top of my head). My solenoid broke and I put in a new one and wired it direct so that it locks when I flip the switch. The trans can't lock in first. I have a 383 with 500 hp or so and run slicks, 31s, or 37s depending on where I am racing or driving with a 88 700r4 with 120k miles with a shift kit. So far it has held up for over 2 years. The geometry and the adjustment of the TV cable must be correct. I am in the process of moving, but if you need the geometry of the kickdown I can look for it and send it to you.
mangus580
282
Western NY
You should really do some google searching on this. Depending on what year the tranny is, what model the vehicle its out of... there is about 5+ different pinouts, and function.
Also, year depending... you can fry the transmission if its not locking up!!
The way I have mine currently wired, it locks up in 2,3,4.... what a PITA.
tut69
Wow...Thanks for all the quik replys. The doner truck was a 1982 1/2 ton diesel. I had the tranny rebuilt by a local tranny shop. The torque converter was replaced with a new one and I am using the transfer case from the donor also. All there is on this tranny is a t/v cable and a square four wire plug. (I have the plugin). I would like the lockup to be as automated as possible so my wife can drive it without hassles of having to turn switches on / off. The donor truck itself is no longer available so i cant get any more parts from it. Thanks for all the help. PS..I am only 45 minutes from Fort Drum NY if I can be of assistance to anyone in that way. Tim
mangus580
282
Western NY
tut, I would suggest you buy the B&M kit. Ask devilman96, he just bought one for his... and says its fully adjustable.
Also, check with your tranny shop... the 82 is a model you shouldnt drive without the lockup happening.
tlm47201
Columbus, Indiana
Get a pressure switch, 45 psi sets the contacts, and install in the governer pressure tap. Governor pressure is 1 pound pressure per mile per hour, so it will disengage below 45 mph. Wire thru brake switch, and the pressure switch, and you should be fine. should have a throttle switch that breaks circuit at half throttle or so for passing.
devilman96
17
Boca Raton, FL
The B&M kit is the way to go as its "girl resistant"... note I didn't say PROOF!
It wires into the speedo and allows you to set the lock up speed which is really nice for towing, other people driving your truck, being 100 % automatic and driving long distances....
Personally I dont see how you guys sit there and flip switches but I do a lot of road and highway driving, on and off of interstates all of the time!
http://www.dougherbert.com/converterlockupcontrolkit-p-18565.html
bgekky3
Huron, Ohio
You can run the trans without the lockup depending on gear ratio and stall speed. Early 80s might not even have a lockup feature. My wife can drive my truck and remember to drive in 3rd around town and put in 4th on the highway and flip a switch when cruising. I dont let my friends that are not capable of flipping a switch when cruising drive my truck. It isnt that hard to remember. You can leave the switch on and put a vacuum and brake switch and have it pretty much automatic.
acmunro
Reynoldsville,PA
tut69, Did you do this swap on a M1008 ? I am looking at doing the same swap from an 82 1/2 Ton Diesel longbed I have. Did you use the 1/2 ton Driveshafts ? Did you have to change the U-joints at the axle ends to match up to the 1 ton differentials ? Were the lengths ok ? Thanks for any help or tips. Al
kennyw
When I pulled the 700R4/NP208 and put in the round pattern TH400/NP208 I used the original driveshafts from my truck. They are the same length overall and use the same driveshafts for the same chassis length.
