75 mph in a Deuce
m715mike
3,922
Montgomery, Texas
For the record, even the LDS is screaming at that speed. 70 is fine for cruising, because it is a few hundred rpm less. I wouldn't run at 75 for any length of time, but it sure brings on a smile when you see your speedometer needle pointing straight down at the floor.:driver:
:whistle::whistle:
Kasper31
South East Michigan
LDT 465 D turbo, 60-62 mph @ 2100r's using a GPS for the speedo. That's where my deuce likes to run and getting 11 mpg.
pulling a 105 with 250 shack made into a camper loaded for a weeks camping.
Jeepsinker
470
Dry Creek, Louisiana
It is kind of interesting that sometimes the truck will run faster at lower rpm, and sometimes it just wont. I guess the clutch could be slipping a bit sometimes, but I've never smelled it if that is the case.
HanksDeuce
264
Prairieville, LA
I never saw 75 mph, but it was a very smooth ride at 72 mph. Jeepsinker has on heckuva nice truck!
Things I notice about this picture:
- GPS indicated 72mph in a 1969 M35A2
- one hand on the steering wheel at the 12 o'clock position
- rain on the windshield
Surprised the safety police haven't busted your chops yet, Garrett. And I ain't asking to be deputized, but be careful out there, bud.
m-35tom
226
eldersburg maryland
Garrett, glad to see you are enjoying the upgrade! Since my engine is rated 3000 rpm continuous duty I guess i should try for a record? Maybe I will just do the math, 80.82 mph with 14.5R20.
rustystud
3,389
Woodinville, Washington
If the engine would turn 8 grand the gearing would be fine with that.
The engine could turn 8,000rpm's but the drivetrain wouldn't like it ! That Spicer 3053 would not like turning that fast at all ! Not to mention the transfer-case or drivelines or differentials ! Remember those high RPM engines are coupled to high tolerance, fine tooth, small gear transmissions with small U-joints and small differentials. The reason everything is small is they are better able to spin-up to high RPM's without coming unglued. Take a large gear, say the Rockwell "Bull" gear and spin that puppy up and see what happens ! Much more spinning mass that is not balanced for that much RPM. NOT GOOD !Can you say "bye-bye bearings" ? I knew you could.
Jeepsinker
470
Tom, give it a try. I don't like to run mine over on the governor for a long time, but I do sometimes run it at 2700 for hours on end.
Also, and I should've mentioned it long ago, but I found a much easier way to get both the counter shaft and mainshaft installed than using the wire and two people trick. Call me sometime and I'll explain it, I'm sure you'll add it to your instructions.
