8.3L Cummins from an excavator
dilligaf13
33
south, florida
I'm looking at a 8.3L Cummins that supposedly came out of an excavator. What if any difference is there between this 8.3L Cummins and the ones in the M939A2? I'm looking at the subpar pictures the guy has and best I can tell they're similar...
If the motors aren't identical what would it take to drop it into a M939A2?
Thanks
74M35A2
340
Livonia, MI
Not enough info given to answer your question. Pics of the engine and description of what remains in/of the truck would help.
74M35A2
340
Livonia, MI
OK. That’s an EFI engine, known as an ISC if 8.3L. They start and run great, and are self contained. I am preparing to do the same. Was the excavator 24 volt? Likely. ECM on it is selectable between 12v and 24v. Electric lift pump on it would need to be switched to 24v if it is 12v, or run the entire engine on 12v. Same with intake grid heater if it has one. Easy to do either way.
Fan drive is missing, those are not cheap. That engine will need a front mounted charge air cooler. If you are putting it in front of a stock M939 auto trans, those are somewhat unique engine flywheel housings, you’d need one of those if the truck does not have it.
Otherwise, just need an electronic throttle pedal, one from a Cummins Dodge Ram works. Just power and ground and she’ll run.
That is a 4 valve engine, so you can put factory Jake brakes on it. I did on mine, but engine not in truck yet.
That turbo will have to be spun 180 degrees so exhaust faces rear, then just re-clock the compressor housing.
The M939xx engine mounts offset the motor heavily to the pass side, just FYI. Oil pan has large recess for front prop shaft. But the base mil 8.3L one fits the newer engine.
My M925a2 8.3L engine is for sale if you want exactly the engine that came out of that truck. The EFI engines are cheaper to buy, I think people are scared of of a few wires. It is really just power, ground, and the accel pedal wires.
dilligaf13
33
south, florida
Sounds relatively easy, if you're just dropping it in a donor truck. I don't need an engine right now or I'd just jump on yours, this is just a spare/back up or I may sell it later. What's the ballpark price on a newly re-built one of these??
Thanks
74M35A2
340
Livonia, MI
Lots of choices @ $5k, mine is less. How much are they asking for that engine, and can they demo it to run before purchase?
74M35A2
340
Livonia, MI
How much are they asking for the engine? Don’t be one-sided and just take. Nobody’s going to steal it from you. I already have one homeless one. Ha!
3,164
If it came out of an off road piece of machinery, most likely 24vdc. The cal will need changing to an automotive type because the cal in is set at variable speed, it will drive like a CAT powered truck, you can try it like that though. IIRC, FW hsg from a mechanical 8.3 will swap over to the ISC, That is a good engine. it has a bosch pump, not the CAPS pos. No aftertreatment either....well, some had cats but those were mostly on road stuff. If I were to have a motorhome, the mechanical 8.3, 1995-6 year model or that engine, 2004-6 ISC would be my choice
74M35A2
340
Livonia, MI
I’d like to have one, maybe 8.9L version, hooked to a 13 speed Roadranger, with Jakes and a polished turbo compressor housing. That be fly.
3,164
I know a guy who has just that set up, want his number? He might want to off the set up 'cause it's taking up too much dead space in the garage.
