Jeepadict
- 536
- 93
- Round Mountain, NV
After an unmotivating winter, I'm making another attempt at this project 802 I have. There was a noteworthy list of problems when I got it, and I'm starting to see the light at the end of the tunnel.
It's a smooth running machine, up until I attempt to go over 74 PRC on the AC Ammeter, then it pulls the engine down below power indicating levels and sometimes will even stall the engine...but never once has it shown any fault lights other than oil pressure AFTER the engine completely stops. Most times reducing the load won't correct the behavior back to normal, I have to remove the load completely before it dies and start again. On occasion when trying to load it the RPMs drop very low but doesn't die, just grumbles along until I open the contact. I'm using a combination of 3 electric space heaters (two ceramic 1000W 110V on opposite legs of the box, one coil wire 5000W 220V) as an improvised load bank (via 50A spider box) to give me flexibility in the load that I apply to the machine. With the engine at full temp, the best truly balanced load I can attain without it dying is 108.2 VAC 18.8A per hot leg using an amp clamp and meter...my math comes to 4068W total. I can get it to pull a slight bit more on one leg (or the other) before it dies, but only 353W worth. When I apply the larger loads I can see the HZ meter drop a bit as I'm used to with my other machine, but where my other 802 will recover and I make slight adjustment to the Frequency Adjust Control this machine just keeps dropping until the HZ meter zeros. Even attempting to max the FAC just before I add a higher load, the machine still bogs down below a functionable level. With all things taken into account, my gut tells me this is most likely a fuel starvation problem...leading me to believe that the Governor requires adjustment or repair.
Disqualifying factors: I've already done a good bit of work to this machine...fixed oil drain line leak, misc wire harness repairs, replaced multiple leaking fuel lines, replaced oil press sending unit, upgraded both well nuts, replaced fuel/oil/air filters and water separator, repaired battery cables, installed new starting batteries, installed missing fuel fill cap, installed many missing case fasteners. All fault lights test good. Remaining discrepancies beyond this low power problem: Oil Press gauge inop, Voltage Adj rheostat bad, and coolant flush. The only thing I have not ruled out yet is the fuel quality, but the fuel is fresh from upgrading the well nuts and I can get the machine to duplicate the failure multiple times over.
In my efforts to scour the TM for the Governor adjustment, the closest task I can find is "4-7 ADJUSTING FREQUENCY DROOP AT ENGINE GOVERNOR". As I'm a big grey airplane guy, and not a ground equipment guy...this is where I find my cause for pause and defer to the judgement of those more experienced than me, because even with the help of the internet I'm having difficulty understanding FQ Droop or the table that depicts the adjustment parameters. I'm all about tinkering, but playing "Parts Darts" is far from my favorite game. Is anyone familiar with this machine's described behavior? When I find the troubleshooting in the TM for a low power condition it flows down a engine failure line of head and valvetrain damage...but that doesn't feel right in this instance.
Thanks in advance! ST
