- 19
- 18
- 3
- NW Ohio
Yeah, this is the oldest 802 I have "99" all my others are 08-10. This one's seen some things. Had a reset tag removed so don't know what level/hours. Meter has 900 hours. Runs great and overall condition is pretty good just those 2 TB's have a bunch of corrosion on the screws.Using an inhibitor definitely won't hurt anything, but usually sets that look like that either sat outside with the cover off or got wet and stayed wet for a while, somehow! That amount of rust and corrosion doesn't typically happen just from normal humidity etc.
Well, it wouldn't bother me to leave it alone if it would be ok. I think it's just the screw heads, that's why I asked "or just leave it alone". So far the consensus has been to clean them up with products recommended or replace the screws. I would be happy to just spray something on them and let them ride as opposed to break each currently good connection fiddle around, put all back together and create an issue for nothing.If it really bothers you, Look up Marco Manufacturing co. in the net. They supplied these terminal strips to the Military. Part numbers are in the TM. If you need help finding them, say something. Call them. They might even sell you just the screws. Or, start a parts wanted thread, and list part numbers and NSN's. Maybe someone is parting out a gen set, and will sell them to you. I can think of several people who do that.
Don't worry about the hours, the meters are not something to rely on anyway as it could have been changed at any any point. The Reset tags don't tell you a whole lot either other than the date it was reset and where.Yeah, this is the oldest 802 I have "99" all my others are 08-10. This one's seen some things. Had a reset tag removed so don't know what level/hours. Meter has 900 hours. Runs great and overall condition is pretty good just those 2 TB's have a bunch of corrosion on the screws.
