- 3,683
- 5,504
- 113
- MA
So finally got around to playing with my 802a yesterday. It seems the unit is getting fuel during the 'priming' stage, but once running... she runs dry about 30 seconds later. I can hear the pump running on both Prime + Run as well as Aux + Run... but is there a separate circuit for keeping the pump running while not in prime stage?
I was getting this, then changed out the inline fuel filter in case it was blocked, but am getting the same thing. The fuel/water separator I could not unscrew to save my life... don't know what the **** I am doing wrong, but these 5kw units certainly are crammed in the case (compared to the 10kws). I can't even get my hand to the front of the block to access the drain T (was flushing the system yesterday).
