- 2,920
- 7,109
- 113
- West greenwich/RI
Any new pictures you can share?
we didn't see any hard contact it seems as the pushrods and rocker arms took all the force . we pulled the radiator and shroud but it looks as the radiator support has to be removed . the large sheet metal frame that holds the radiator is what we are referring to.Don't worry about the head gasket thickness, my experience has been that using the "standard" thickness gasket that comes in the gasket kits works just fine.
I'm not even sure if you can still buy the other thicknesses or not.
You should just remove the radiator and shroud assembly. Its easy and I think only 6 or 8 bolts to remove it.
So there is no damage to the valves or pistons, but I assume there are round marks in the carbon buildup on the pistons where the valves touched?
Or do you mean the valves did not hit the pistons at all??
Ray, where is the best place to buy a engine gasket set that isn't from China?You have a Lister LPW4 in an MEP 803A that was made for Onan & they name it the DN4. Don't use the China copy parts, it is not worth it.
Perhaps more to the point, there are no packages being shipped from the UK at the moment due to that uncertainty.Here's a better deal on Ebay.UK but I have no idea about any import duties or any additional expenses these days!
we have the camshaft ready to remove, all lifters and fuel pump tappets have been taken out and the two bolts for the camshaft retaining plate have been removed as well . the camshaft doesn't want to budge are we missing anything ? we went over the manual and it appears we covered everything.Don't worry about the head gasket thickness, my experience has been that using the "standard" thickness gasket that comes in the gasket kits works just fine.
we tried again today and the camshaft still wont budge. its almost like there is a retainer or bolt is still holding it steady. I was thinking between the crankshaft and the oil pump drive gear is keeping it from walking out. all the steps were performed from the TM . any thoughts?we have the camshaft ready to remove, all lifters and fuel pump tappets have been taken out and the two bolts for the camshaft retaining plate have been removed as well . the camshaft doesn't want to budge are we missing anything ? we went over the manual and it appears we covered everything.
Ray , no 3rd bolt and we removed all the tappet related components. We did not remove the tappet studs as they are about the camshaft. We are going try loosing the oil pump to see if that helps . Again thanks for help2 other things! On the Cam retaining plate there are 3 bolts, you mentioned you removed 2, is the plate still tight or free to spin around? If tight you probably missed he 3rd bolt.
On the metering pump tappets did you remove the alignment bolts and pull out both the thin Cup as well as the actual tappet, or just the Cup?
My money says you missed the 3rd bolt in the cam retaining plate.
