LuckeyD
- 428
- 63
- Vilseck, Germany
Good Day. Your initial issue is your gen shuts down after a while on a load that is gradually increased with messing with it. The key was when the oil pressure gage goes under 20PSI. The LOP switch shuts you down as it is set at about 20PSI or just below. Fresh oil allows it to go a while then you shut down again; am I correct? Again oil pressure was below 20PSI on your gage.
Please put an oil gage on the thing and i recommend using the same oil line as that LOP. Now you read on a gage what you have confirming the gens already in place gage system. Please note your pressure especially on shut down. Should start out about 40 +and decline to 20 or less upon shut down. If this is the case, you have work to perform. Here is a test, with gage attached, disconnect the LOP wiring. Observe pressure as gen warms up and it will go longer but shut it down below 15-18 PSI.) What's happening is as oil passage ways and oil pump bypass pressure setting warm up the bypass setting is allowing too much oil to bypass.
Add this to main bearing wear, your oil pressure will not allow the engine to keep running and the LOP shuts you down. Using 50 weight oil will only prolong things a tiny bit. You can test piston rings for compression, they will probably be in tolerance or hair line in tolerance. Using plastigage you can read the main bearing wear.
I had one Warrant Officer try adjusting the oil pump bypass and had oil leaks everywhere as it was adjusted too high. Touchy setting. There should be a Lister-Petter engine manual in the forum for tolerances and settings as you rebuild your engine. Onan has parts, but may take a while to obtain bearings, rings and oil pump(the bypass setting is touchy). I do hope I am all wet, but I have seen this action countless times in war zones. Let us know what you find.......
