803A smoking and surge after warm up
America
35
USA
Hi I’ve been lurking around the forum a few years and recently purchase a mep803-A.anyway Its surging a couple hertz and has produced large amounts of carbon build up in the exhaust in just a few hours. I have changed the fluids and filters and cleaned the switch’s . Hopefully someone can point me in the right direction? Thank you
Chainbreaker
2,112
Oregon
Would be helpful to know a bit of history...
1. Did you purchase it from a Gov't auction or Private individual?
2. How many hours on Hobbs meter?
3. Has it been sitting unused or do you know when it was last run and if it ever ran right?
4. Have you flushed the fuel system and put in fresh diesel?
4. Are you running it with a load or unloaded?
5. What does exhaust look like?
Coug
4,764
Olympia/WA
Another question, what type / how much load was it under during your few hours of run time? Just "loaded/unloaded" can be open to a lot of interpretation.
America
35
USA
1. Did you purchase it from a Gov't auction or Private individual? Private
2. How many hours on Hobbs meter? 110
3. Has it been sitting unused or do you know when it was last run and if it ever ran right? It has been unused, the exhaust build up looked normal until I stated it.
4. Have you flushed the fuel system and put in fresh diesel? Yes
4. Are you running it with a load or unloaded? Both and it has the same problem either way.
5. What does exhaust look like? It is literally filling with black carbon.
America
35
USA
It has run all the way up to 12,000 watts and held it. Its running heaters That add up to 12,000 for testing. Also like I said the problem is happening independent of load. Hopefully this info helps Thank you
Chainbreaker
2,112
Oregon
5. What does exhaust look like? "It is literally filling with black carbon."
Just to clarify...What does actual exhaust plume look like? Are you saying the inside of the exhaust pipe outlet became heavily coated as you ran it and is increasing? And by saying you "changed filters" you did check air filter & housing?
The fact that you say its "load independent" makes me wonder if you might have a bad/stuck injector. I'd try putting some injector cleaner (Seafoam or similar) in fuel and run it for 15 min or so and then let it sit a few hours or overnight and then run it loaded ~ 75% for an hour and see if it improves.
Ray70
7,113
West greenwich/RI
If you have an IR thermometer you can try checking the exhaust temps on each cyl. this can give an indication of a sticky injector.
Or you can take the 10mm nuts off the exhaust manifold and lift it up slightly and use a flashlight to see which cylinder is smoking. You can do this with the top cover on or remove the top cover and take the manifold / muffler off completely for a better view. Also look at the paint on the block and head. You may see some discoloration if one cylinder is running extremely hot from a stuck injector.
America
35
USA
Just to clarify...What does actual exhaust plume look like? Smoking gray black
Are you saying the inside of the exhaust pipe outlet became heavily coated as you ran it and is increasing. Correct it has made almost a centimeter of buildup inside obviously not normal
And by saying you "changed filters" you did check air filter & housing? Yes I did
I did this as well. A whole tank full of the gum out brand. Maybe I should try sea foam as well?
America
35
USA
I tried to use my IR thermometer and everything seems normal. I will take off the exhaust to see witch cylinder or cylinders are the problem this evening. Thank you
Chainbreaker
2,112
Oregon
I did this as well. A whole tank full of the gum out brand. Maybe I should try sea foam as well? I think they all use similar chemicals but I've had good results using Seafoam myself and others seem to like the results. But I doubt that if the Gumout brand did nothing that something else in a can is going to fix the issue, unless you used it under the recommended dosage or it just needed more time to work. I think Ray's recommendation to try to find the offending cylinder/s is the right direction to troubleshoot further.
America
35
USA
I took off the exhaust and it seems to look a even color coming out of each cylinder. What does this tell me? Thanks
Zed254
468
S. Hampton Roads, VA
I keep thinking fuel and air. How long did it run at 12Kw? If it ran an hour then I suspect air flow is good and your air intake hose is not crimped. Bad fuel pump? Sustained run at 12Kw suggests good air AND fuel flow. Crappy fuel?
America
35
USA
It ran for a couple hours at 12KW. I noticed that the rpm go up and down in a rhythm. I’ve seen other mep do the same thing when to much load is put on at once. But my 803A is doing it without a load and with. Also the diesel is brand new, and running other things perfectly. Thank you
America
35
USA
Also the fuel pump is working.
Zed254
468
These articles all support Chainbreaker 's and Ray70's analyses: bad/stuck injector (s?).
I'd hit it with Seafoam again before pulling them.
America
35
USA
Okay I pumped the diesel tank out again. I then put one gallon of seafoam and one gallon of diesel in the tank. I will let it run a hour and then turn it off to soak over night. Thank you.
America
35
USA
I think it’s the governor. Has anyone rebuilt one of these governors? If so what could be wrong with it, I was thinking bad springs. The way it sounds and runs is like when you changed the load really fast on a perfectly working unit. The only difference is that in a perfect unit it quickly goes away within minutes usual completely. It must be the problem. Anyone have any thoughts?
Ray70
7,113
West greenwich/RI
I've been in the governors before, but only with the engine removed. Not sure how well you can see or access things unless you at least remove the radiator and housing. After that removing the front cover is simple. I've seen issues with incorrectly assembled internal linkage and other issues with the fuel rails being bent etc.
Either way, it's pretty easy once you get in there and follow the diagrams in the TM.
